FME Server New User with Basic fmeuser Role seeing Admin Folders
  • Oct 20, 2023 4:52 PM UTC
  • 60 views
fmelearner
Forum|alt.badge.img+3
I have added a new team member into FME Server, with fmeuser role. Basically this user only care read and Run workspaces under Parks repository so in FME Server under  Repositories slide-down I set this configuration
imagebut when I checked the user in the Server end point I am seeing this:
imageAs you can see two Samples and Tools repositories also listed there! When I check back in Server side, looks like there are some circled-checks on read and run options for these two!
imageNow can you guys pleas let ne know how I can force this user to ONLY have access into Parks repository using the fmeuser role.
damiobasa
  • Oct 26, 2023 4:02 PM UTC
Hello
The samples and tools repository come by default with the "fmeuser" role. If you would like to limit this access further, I would advise you to un-assign the "fmeuser" role from the user and then create a new role and provide granular access on that role for the repository the user should have access to.
