FME server job for 23M records fails on one environment but succeed on another. Comparison of initial memory resources shows that the starting point for both jobs is the same, however memory fragmentation differs.
  • May 14, 2021 1:09 PM UTC
  • 70 views
zaneta.mark
FME server job for 23M records fails on one environment, but succeeds on another. Comparison of initial memory resources shows that the starting point for both jobs is the same:
log_comparison
However, a comparison of memory fragmentation in those environments shows some differences as follow:
engine_comparison
Is it possible that memory fragmentation causes that on one FME Server Engine job succeeded, but on the other failed?
richardatsafe
Forum|alt.badge.img+11
Hi @zaneta.mark​ ,
It's possible memory fragmentation is the problem. It might be worth a) checking to make sure there are no other job/processes running on those machines when this job runs. and b) compare the swap/page file settings on the two machine to make sure they are using memory the same way.
hkingsbury
Forum|alt.badge.img+73
  • May 16, 2021 10:10 PM UTC
I've faced memory issues in virtualised environments when the Windows VM has had memory allocated to it in the Hypervisor but not reserved. This was resulting in over allocation of memory on the host and causing things to fail on one machine, but not on the other
