FME Server Error: MAXIMUM_COUNT clause must specify an integer. Value 'None' is invalid
  • May 30, 2018 3:58 PM UTC
  • 0 replies
  • 49 views
I have developed a workspace that makes a HTTP call then returns the parsed JSON response. It runs from FME desktop successfully, but when published to FME Server as a streaming service I get the following errors:
Creator_CREATED Brancher -1 4(BranchingFactory): MAXIMUM_COUNT clause must specify an integer. Value 'None' is invalidMAXIMUM_COUNT clause must specify an integer. Value 'None' is invalid
From the logs it's failing just initializing the workbook and before trying to connect and make the HTTP call. I was unable to find a similar error anywhere else.
