Flow auto-reading changes made to workspaces in Form
  • Nov 21, 2023 9:13 AM UTC
  • 95 views
scarter
Forum|alt.badge.img+10
Hi Group,
Imagine I create a workspace in Form which is then published to Flow. I'd then run this via Flow, and it runs fine. But if I then make a change in the original workspace in Form (even a tiny change like change the destination of a writer, or add a new transformer somewhere), do I then have to republish the workspace from Form to Flow? Or does Flow automatically pick up on changes made to the workspace in Form?
Thanks,
Stuart
  • Nov 21, 2023 9:18 AM UTC
There is (currently) no automatic synchronization, you'll have to manually publish your modifications to Flow each time.
scarter
  • Nov 21, 2023 9:47 AM UTC
Thanks for that, david_r. Stuart Carter Geospatial Manager Southwark Council Technology and Digital Service 160 Tooley Street London, SE1 2QH Tel: 0207 525 5409 stuart.carter@southwark.gov.uk Southwark Maps<https://geomap.southwark.gov.uk/connect/analyst/mobile/#/main> Historic map downloads
