experssion for string
Forum|alt.badge.img+5
i need to get the email address from this
[{""email"":""228_mg_primarydistribution@hotmail.com""}]
And
 "token": "-QPWNTxHkE4R1TM8u_M1AOUohy0X2i69BMJBEy0oUDZnqugzS4IKCWiAMrI6YqbLDxJKDyahZ0vrhoAj7FQ49EM4AWkxohFN54D5vJJLzxxR6M_3xcb2mI4iG8E0WDj3fR1my34kAB0_oRNcfNlueTm-jwpxb-OI6WxCJoLkvzaF9y74XYmGUbBeISz1Wmr-U5nFxUCrXbVOtEt5bd9Qh5qwrc9nZeZ6W7uP0oUyXs-wmqHxFxXOl7dhho4LmD-0bo2525vNwKvEZRsgfn6ep8WC264IfwNW7h7UvFX1d6Y.",
 "expires": 1665744258308,
 "ssl": true
and other query i need extract only bold values
Best answer by asadamjad
for 2nd i get this error
  • October 14, 2022
For the first one you can use a JSONExtractor with the following expression:
json[0]["email"]
This will extract the first element of the outer JSON list, then retrieve the value of the "email" key within that element.
It's pretty much the same for the second one, except that there's no list, so you can query the value directly:
json["token"]
You can read more about these expressions in the documentation: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsonfragmenter.htm#JSON_Queries
This one is perhaps the best introduction if you're not too familiar with JSON: https://community.safe.com/s/article/tutorial-getting-started-with-json
  • October 14, 2022
its rejecting
  • October 14, 2022
  • October 14, 2022
The configuration of the JSONExtractor is most likely wrong. It should look something like this:
  • October 14, 2022
give me same error
  • October 14, 2022
fin the attach WS
  • October 14, 2022
asadamjad wrote:
fin the attach WS
The attachement only contains the log, not the workspace. Can you please rather post a screenshot of your JSONExtractor settings.
  • October 14, 2022
asadamjad wrote:
its rejecting
The configuration of the JSONExtractor in the screenshot above is wrong, please compare to the screenshot I posted below.
  • October 14, 2022
  • October 14, 2022
asadamjad wrote:
Check if the quotes (") of the contents of attribute sent_to are doubled, they seem to be in the example at the top of this post, and that's not valid JSON.
If yes, you can use a StringReplacer to replace "" with " before the JSONExtractor.
