experssion for string
  • Oct 14, 2022 9:00 AM UTC
  • 10 replies
  • 125 views
asadamjad
Participant
Forum|alt.badge.img+12
i need to get the email address from this
[{""email"":""228_mg_primarydistribution@hotmail.com""}]
And
 "token": "-QPWNTxHkE4R1TM8u_M1AOUohy0X2i69BMJBEy0oUDZnqugzS4IKCWiAMrI6YqbLDxJKDyahZ0vrhoAj7FQ49EM4AWkxohFN54D5vJJLzxxR6M_3xcb2mI4iG8E0WDj3fR1my34kAB0_oRNcfNlueTm-jwpxb-OI6WxCJoLkvzaF9y74XYmGUbBeISz1Wmr-U5nFxUCrXbVOtEt5bd9Qh5qwrc9nZeZ6W7uP0oUyXs-wmqHxFxXOl7dhho4LmD-0bo2525vNwKvEZRsgfn6ep8WC264IfwNW7h7UvFX1d6Y.",
 "expires": 1665744258308,
 "ssl": true
and other query i need extract only bold values
Best answer by asadamjad
for 2nd i get this error
  • Oct 14, 2022 10:19 AM UTC
For the first one you can use a JSONExtractor with the following expression:
json[0]["email"]
This will extract the first element of the outer JSON list, then retrieve the value of the "email" key within that element.
It's pretty much the same for the second one, except that there's no list, so you can query the value directly:
json["token"]
You can read more about these expressions in the documentation: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/jsonfragmenter.htm#JSON_Queries
This one is perhaps the best introduction if you're not too familiar with JSON: https://community.safe.com/s/article/tutorial-getting-started-with-json
asadamjad
Participant
  • Participant
  • Oct 14, 2022 12:17 PM UTC
its rejecting
asadamjad
Participant
  • Participant
  • Oct 14, 2022 12:22 PM UTC
  • Oct 14, 2022 1:15 PM UTC
The configuration of the JSONExtractor is most likely wrong. It should look something like this:
asadamjad
Participant
  • Participant
  • Oct 14, 2022 2:02 PM UTC
give me same error
asadamjad
Participant
  • Participant
  • Oct 14, 2022 2:05 PM UTC
fin the attach WS
  • Oct 14, 2022 2:47 PM UTC
fin the attach WS
The attachement only contains the log, not the workspace. Can you please rather post a screenshot of your JSONExtractor settings.
  • Oct 14, 2022 2:49 PM UTC
its rejecting
The configuration of the JSONExtractor in the screenshot above is wrong, please compare to the screenshot I posted below.
asadamjad
Participant
  • Participant
  • Oct 14, 2022 3:04 PM UTC
  • Oct 14, 2022 3:08 PM UTC
Check if the quotes (") of the contents of attribute sent_to are doubled, they seem to be in the example at the top of this post, and that's not valid JSON.
If yes, you can use a StringReplacer to replace "" with " before the JSONExtractor.
