Error with FME Server and ArcGis Server (Enterprise) license
  • January 12, 2022
  • 9 replies
  • 110 views
Hey everyone.
Our company rented server (Windows Server 2016) where we've got ArcGiS Server (Enterprise) + FME Server. And some FME jobs (workbenches) using FME SDE Readers. So reades takes some vector objects from SDE base and then make some transformations with them. And all works fine.
Week ago we are migrated to another server. So we are reinstall ArcGiS Enterprise (+ restore backups) and then reinstall FME server (+restore backups too). All jobs working fine except those, which are using FeatureReader "Esri Geodatabase (ArcSDE Geodb)". Is some reason when I'm tried to start jobs I've got an error
74	2022-1-12 18:57:56 | Creating reader for format: Esri Geodatabase (ArcSDE Geodb)
75 2022-1-12 18:57:56 | Trying to find a DYNAMIC plugin for reader named `GEODATABASE_SDE'
76 2022-1-12 18:57:56 | Loaded module 'GEODATABASE_SDE' from file 'C:\Program Files\FMEServer\Server\fme\GEODATABASE9.dll'
77 2022-1-12 18:57:56 | FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20200115)
78 2022-1-12 18:57:56 | Performing query against GEODATABASE_SDE dataset `<Unused>'
79 2022-1-12 18:57:56 | Creating reader for format: Esri Geodatabase (ArcSDE Geodb)
80 2022-1-12 18:57:56 | Trying to find a DYNAMIC plugin for reader named `GEODATABASE_SDE'
81 2022-1-12 18:57:56 | FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20200115)
82 2022-1-12 18:57:56 | Opening the Geodatabase reader
83 2022-1-12 18:57:57 | Unable to perform any licensing related tasks. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server. Refer to this this article http://fme.ly/qua for more details
84 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
And then another bunch of errors
102	2022-1-12 18:57:57 | Creating reader for format: Esri Geodatabase (ArcSDE Geodb)
103 2022-1-12 18:57:57 | Trying to find a DYNAMIC plugin for reader named `GEODATABASE_SDE'
104 2022-1-12 18:57:57 | FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20200115)
105 2022-1-12 18:57:57 | Performing query against GEODATABASE_SDE dataset `<Unused>'
106 2022-1-12 18:57:57 | Opening the Geodatabase reader
107 2022-1-12 18:57:57 | Unable to perform any licensing related tasks. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server. Refer to this this article http://fme.ly/qua for more details
108 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
109 2022-1-12 18:57:57 | FeatureReader (QueryFactory): A fatal error has occurred. Check the logfile above for details
110 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
111 2022-1-12 18:57:57 | AttributeFilter_Filter (AttributeFilterFactory):
112 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
113 2022-1-12 18:57:57 | StringReplacer_2 (StringReplacerFactory):
114 2022-1-12 18:57:57 | AttributeKeeper (AttributeKeeperFactory): A fatal error has occurred. Check the logfile above for details
115 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
116 2022-1-12 18:57:57 | StringReplacer (StringReplacerFactory):
117 2022-1-12 18:57:57 | AttributeKeeper_2 (AttributeKeeperFactory): A fatal error has occurred. Check the logfile above for details
118 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
119 2022-1-12 18:57:57 | FeatureJoiner (FeatureJoinerFactory): A fatal error has occurred. Check the logfile above for details
120 2022-1-12 18:57:57 | FeatureJoiner (FeatureJoinerFactory): A fatal error has occurred. Check the logfile above for details
121 2022-1-12 18:57:57 | A fatal error has occurred. Check the logfile above for details
So, in some reason, FME Server didn't see ArcGIS Server license.  As I understand correctly. How can I solve this error? May be there is configuration file for FME somewhere and I need to write arcgis server license inside it.
We are using FME Server 2020.2.5.1 Build 20828 - win64
Any help would be nice
Best answer by swatto
So you're still have same problem? Even with last Enterprise and FME server version error still exist ?
I did, however it was resolved this way:
1. ensure that you have upgraded your FME desktop software to match the server version (2021.2 or higher);
2. ensure you have an up to date version of arcgis pro on the desktop machine (2.9.1);
3. Open the workspace in FME;
4. goto Workspace Parameters>Translation>ESRI ArcGIS Compatibility and set it to ArcGIS pro.
5. save and Republish the workspace to FME server.
With major releases of FME/ArcGIS, the whole platform must upgrade together.
Forum|alt.badge.img+62
Do you have the 64-bit Background Geoprocessing installed as part of your ArcGIS setup?
  • January 13, 2022
Nope. As I know Background Processing as avilable only for ArcGIS Desktop (ArcMap) and cannot be installed without it. But we have ArcGiS Server (Portal + Server + DataStore), 10.9.1 version. So it's another type of product.
swatto
  • January 14, 2022
I have the same problem.
ArcGIS Server machine running ArcGIS enterprise 10.9.1
FME Server installed on same machine version
FME Server 2021.2.1.1
Build 21805 - win64
swatto
  • January 14, 2022
Note that 10.9.1 is matched to FME server 2021.2 and higher. So if you are using FME 2020.5 you have a problem there.
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility#ArcGISEnterprise
swatto
  • January 14, 2022
Further to this, if you intend to use Enterprise version 10.9.1
I've just gone through this procedure and no longer get the error.
  • January 14, 2022
Build 21805 - win64
swatto
  • January 16, 2022
  • January 18, 2022
Finally, problem solved. It was compatibility question. Only FME Server 2021.2.*.* can see license from Arcgis Enterprise 10.9.1
nielsgerrits
Forum|alt.badge.img+64
This. For future reference, this is documented in Notes on FME and Esri Versions and Compatibility.
