I am using FME Server to run a workspace that has 2 optionals user parameters published. After launching the workspace, everything is ok.
Next time I go to run the workspace, the optional parameter is set with the previous value.
The user can click on the "reset" button to clear by himself, but I would like to know if there is a way to automatically clear these optional parameter values in FME Server?
Kind regards,
Aymeric
Best answer by richardatsafe
Hi @Aymeric VIAUD ,
Unfortunately, I don't see a way of proactively resetting the values. It appears to be configured on the browser side, and your default values should always come in if you open a new browser and haven't cached anything. That being said an Admin toggle to automatically reset all workspace values when the run workspace page is opened might be a good enhancement. Would you be willing to post this to ideas if that matches what you are looking for?
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
