Do not save optional user parameter value after running workspace
  • Oct 17, 2022 8:50 AM UTC
  • 171 views
Dear all,
I hope the community is fine 🙂
I am using FME Server to run a workspace that has 2 optionals user parameters published. After launching the workspace, everything is ok.
Next time I go to run the workspace, the optional parameter is set with the previous value.
  Exemple" data-fileid="0694Q00000L5f3TQAR The user can click on the "reset" button to clear by himself, but I would like to know if there is a way to automatically clear these optional parameter values in FME Server?
Kind regards,
Aymeric
Best answer by richardatsafe
Hi @Aymeric VIAUD​ ,
Unfortunately, I don't see a way of proactively resetting the values. It appears to be configured on the browser side, and your default values should always come in if you open a new browser and haven't cached anything. That being said an Admin toggle to automatically reset all workspace values when the run workspace page is opened might be a good enhancement. Would you be willing to post this to ideas if that matches what you are looking for?
richardatsafe
Forum|alt.badge.img+11
  • Oct 17, 2022 9:45 PM UTC
  • Oct 18, 2022 7:02 AM UTC
Hi @richardatsafe​,
So, I will tell the users to click on the reset button before they use the workspace.
Thank you for the quick answer.
