Disable FME Server schedule using REST API
  • Dec 12, 2018 3:49 PM UTC
  • 102 views
sunsilk11
Hi I would like to disable the schedule in FME Server in the event of a job failure.
I am looking at https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/schedules/update_put_3
which works but it seems that I have to update all the parameters in the schedule for this to work, rather than just the parameter "enabled".
I would like to set the request body as
"enabled": false
Has anyone manage to get this working by just setting enabled to false ?
itay
Forum|alt.badge.img+19
  • Dec 12, 2018 7:07 PM UTC
Looking at the documentation shows that only a few parameters are not optional, these are the only ones you need to supply, I never tried it my self but I think you cannot just change only the enable tag.
Hi @sunsilk11,
As itay mentioned only a few parameters are optional. Instead what you could do is first use the GET response to read in the current schedule set up, then use a StringReplacer to change the "enabled":false to "enabled":true and then use a second HTTPCaller with the PUT request to upload the modified response.
  • Dec 13, 2018 12:44 AM UTC
