Deploy FME Server on the Digital Ocean droplets Cloud and ESRI systems
dor1411993
Forum|alt.badge.img+5
Hi everyone!
In order to reduce increases, we want to move the FME Server in the cloud, currently on the AWS platform, to the Digital Ocean platform.
The best options are installation on top of Linux.
I know FME will work great with Linux, our problem is that we work continuously with ESRI systems (sde,gdb), and I know it requires an ArcPro or Enterprise license, at least on Windows.
Is the situation similar in Linux?
I ask, because ArcGis Pro does not have a Linux deployment option.
Would appreciate help!
Thanks!
Best answer by kate-safe
Hi @dor1411993​ ,
Most Esri formats are restricted to Windows environments only. The article below helps outline the compatibility of the various formats with not just versions of FME but also OS
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
I hope this helps provide some clarification!
  • May 2, 2023
Legally, I believe you need to install ArcGIS Enterprise on the same machine as your FME Server.
But for a more nuanced explanation, have a look at this article: https://community.safe.com/s/article/using-fme-server-with-esri-software
nielsgerrits
Forum|alt.badge.img+54
I believe that SDE support is Windows only. Safe used to have an informative page with supported formats and operating systems here but since the rebrand the info is hard to find.
dor1411993
  • May 2, 2023
Thanks you all!
If someone from @safesoftware safesoftware​ can help us, it will be great.
And @david_r​ ,if I understood correctly, what you suggges will help with gdb, but not sde..?
  • May 2, 2023
dor1411993 wrote:
Thanks you all!
You can read and write FGDB without using any ArcGIS libraries, with some caveats. Otherwise you'll need the licensed ArcGIS libraries, however I cannot say anything about Linux compatibility here.
See also:
https://community.safe.com/s/article/comparison-of-fme-readers-and-writers-for-sde-and
kate-safe
Forum|alt.badge.img+7
  • May 2, 2023
Hi @dor1411993​ ,
dor1411993
  • May 2, 2023
katebrillinger wrote:
Hi @dor1411993​ ,
Thanks @katebrillinger​!
