Cryptic error messages
  • September 11, 2020
  • 21 views
hkingsbury
Forum|alt.badge.img+67
Hey all
Have a server process that is running some parrallel processing and its failing with some really bizarre cryptic errors.
The machine has more than enough ram (36gb) and plenty of temp drive space (100gb free). Any one have any thoughts on a way forward?
Running on 2019.2.1 build 19823
MicrosoftTeams-image (1)
Best answer by hkingsbury
Looks like a problem lay with the configuration of the virtual machine FME Server was running on. Found some references to FME not liking dynamic memory allocation on the VM host, after changing the way the memory had been allocated things seem to be working as expected.
https://community.safe.com/s/question/0D54Q000080hTKMSA2/why-doesnt-fme-2015-64bit-use-more-memory-on-a-virtual-machine-with-dynamic-memory-management
https://community.safe.com/s/article/performance-tuning-fme
This looks like a case for Safe support, send them all the FME Server system logs, as well as the workspace and a job log.
hkingsbury
  • September 17, 2020
