connection timed out error: Postgres
  • November 24, 2021
  • 115 views
I am trying to convert an old script that loads 100+ tables in Postgres to a FME Server automation. One of the things I am doing is a
INSERT INTO schema1.table SELECT * FROM schema2.table
with a SQLExecutor where schema2 is a Oracle foreign table. This works fine for some smaller tables, but for a large table around 33gb I eventually receive a 'could not receive data from server: Connection timed out' error whether I run it on desktop or server. This worked fine when run from the script. I'm at a loss here, what could be causing the problem?
marcyeranos
  • January 11, 2023
Hello, have you figured it out? If not yet, I think there will be a timeout settings. The Postgres server or the FME Server may have a connection timeout setting that is too low. An alternative is to create a spatial index if this is not the case.
klokker11
Participant
Forum|alt.badge.img+3
  • Participant
  • November 20, 2024
Following this question as I’ve run into the same issue, and have checked the timeout settings on my database which is disabled.
