Any idea on the solution to this pfx certificate importing into keystore error. keytool error: java.io.IOException: DerInputStream.getLength(): lengthTag=109, too big.
  • Feb 1, 2021 3:31 PM UTC
  • 7 replies
  • 1808 views
billybob
I'm configuring fme (fme server 2019.1.3.1) to use https. When I try importing a pfx wildcard certificate into the tomcat.keystore and I'm get the following error:
Importing keystore C:\\certificates\\xxxxxxx.xxx.pfx to tomcat.keystore...
Any thoughts on what the error might be and how to fix it?
Thanks!
warrendev
Forum|alt.badge.img+28
  • Feb 1, 2021 3:40 PM UTC
@billybob​ ,
Are you running this command when you receive that error?
keytool -importkeystore -srckeystore <certpath>\<certificate_name>.pfx -srcstoretype pkcs12 -destkeystore tomcat.keystore -deststoretype jks
 I've found this article going over that error. Maybe this can help.
billybob
  • Feb 1, 2021 3:50 PM UTC
This is the command: >keytool -importkeystore -srckeystore <certpath>\\<certificate_name>.pfx -srcstoretype pkcs12 -destkeystore tomcat.keystore -deststoretype pkcs12 The command you have shows "-deststoretype jks" as the last option. Is that the issue?
warrendev
  • Feb 1, 2021 3:59 PM UTC
I know you can set it to either of those, but the "jks" worked for me. I'm not really sure if that will fix it on your end.
https://community.safe.com/s/article/fme-server-and-httpsssl-pfx-certificate
billybob
  • Feb 1, 2021 4:03 PM UTC
Great! I'll give that a try. Thanks for the article pointer. That helps confirm that I'm using the latest configuration instructions.
billybob
  • Feb 1, 2021 4:36 PM UTC
Thanks. That worked for me. After making the required configuration changes to the various tomcat files, I can't seem to access https://localhost.. Any thoughts on that issue?
Hi @billybob​ ,
Please can you review the log files located in <FMEServerFileShare>/Resources/Logs/tomcat. In particular look in the catalina.log for SEVERE messages, this should tell us what is going on.
billybob
  • Feb 1, 2021 6:32 PM UTC
Hi @hollyatsafe,
I was able to figure out the issue. Some how the tomcat.keystore was corrupted. I simply remove the keystore, recreated it by importing the certificate again, and verified the changes to the xml files. That worked, and I'm able to access https://localhost now. Thank you the response. Reviewing the logs if I have any other is should come in handy.
Thanks again!
