After implementing https on fme server the Backup_Configuration schedule generates 0 kb files
  • Jul 20, 2022 7:11 AM UTC
  • 117 views
stalknecht
Forum|alt.badge.img+22
FME 2021.2.5.0 (20220331 - Build 21816 - WIN64)
Here is a part of the log:
2022-07-19 13:45:31|   0.0|  0.0|INFORM|FME Configuration: Command line arguments are `fme' `Utilities\backupConfiguration\backupConfiguration.fmw' `--FME_SHAREDRESOURCE_DATA' `D:/ProgramData/Safe Software/FME Server///resources/data/' `--HULP_Bestanden' `\\FMENT03\D$\FME_SERVER_HULPBESTANDEN' `--FME_SERVER_PORT' `7071' `--FME_SERVER_ROOT' `D:/ProgramData/Safe Software/FME Server//' `--FME_SECURITY_USER' `dwstalk' `--FME_DATA_REPOSITORY' `D:/ProgramData/Safe Software/FME Server///resources/system/temp/upload/' `--FME_ENGINE' `FMENT03_Engine2' `-LOG_FILENAME' `D:/ProgramData/Safe Software/FME Server///resources/logs/engine/current/jobs\70000\job_70459.log' `--FME_SHAREDRESOURCE_ENGINE' `D:/ProgramData/Safe Software/FME Server///resources/engine/' `--BACKUP_DESTINATION' `$(FME_SHAREDRESOURCE_BACKUP)ServerConfigPackage.fsconfig' `--FME_JOB_CONTEXT' `context-id-76a5b5f4-efd6-40e3-b755-e4a875542bed' `--FME_SERVER_WEB_URL' `http://FMENT03:80' `--FME_SHAREDRESOURCE_LOG' `D:/ProgramData/Safe Software/FME Server///resources/logs/' `--FME_SHAREDRESOURCE_TEMP' `D:/ProgramData/Safe Software/FME Server///resources/temp/' `--FME_JOB_ID' `70459' `--FME_MF_NAME' `backupConfiguration.fmw' `--BACKUP_APPEND_DATE' `Yes' `--FME_SHAREDRESOURCE_DASHBOARD' `D:/ProgramData/Safe Software/FME Server///resources/dashboards/' `-FME_ENGINE_MEMORY_REDLINE' `0.5' `--SERVER_PASSWORD' `***' `--FME_SHAREDRESOURCE_BACKUP' `D:/ProgramData/Safe Software/FME Server///resources/backups/' `--FME_SHAREDRESOURCE_SYSTEM' `D:/ProgramData/Safe Software/FME Server///resources/system/' `--FME_SECURITY_ROLES' `["user:superman","fmesuperuser","fmeadmin"]' `--FME_SERVER_HOST' `localhost' `--SERVER_USERNAME' `superman'
The FME_SERVER_WEB_URL parameter is different then the value that's in the fmeServerConfig.txt. Can anyone explain why?
Best answer by markwatsafe
Hi @stalknecht​, I suspect your FME Server hasn't been restarted yet, so the updated https URL in the fmeServerConfig.txt hasn't been applied. Changes in the config files require restarts so that this information is updated in the server database. Could you see if that resolves the issue or not?
markwatsafe
Forum|alt.badge.img+11
  • Jul 25, 2022 3:34 PM UTC
stalknecht
  • Jul 26, 2022 6:48 AM UTC
Thanks, rebooting the operating system did the trick!
