Zoom to selected features - bug?
  • Jul 13, 2021 7:22 AM UTC
  • 8 replies
  • 199 views
connecter
Forum|alt.badge.img+10
after some time in a workflow I often get a problem that the "zoom to selected features" is greyed out. Also the highlighting of the feature is not displayed any more.
I try all, but only closing the program helps. Have anyone the same problem? The separat Data Inspector program don't have the problem.
I have the newest Version of FME 2021.1, old version have also the same problem.
kailinatsafe
Forum|alt.badge.img+24
Hello @connecter​ , this sounds very strange. Would you be able to shed light on the following questions:
  1. What is your operating system?
  2. Are you viewing 2d or 3d data?
  3. Are you able to share a video or screenshot the behaviour?
Best, Kailin.
connecter
  • Jul 20, 2021 6:34 AM UTC
Hi @kailinatsafe​,
thanks for you reply.
  1. Windows 10
  2. 2D Linedata
  3. Animation
All transformer previews are not working after the problem happened. You can select a row in the table (from the Visual Preview), but the button "zoom to selected feature" is grey out. I tried the following without solving the problem:
  • rerun the workflow
  • Purge Temporary Files
Only shutdown the program help, but it will soon happen again after some time. My colleague has the same problem.
kailinatsafe
Hey again @connecter​ , could you share the FME version/build where you experience this? Also, can I have you confirm the Data Inspector is working properly? Thanks, Kailin.
connecter
  • Jul 21, 2021 6:08 AM UTC
Hi again @kailinatsafe​ ,
yes, I can confirm that. After you start the Data Inspector from the Visual Preview all is working well.
We use FME(R) 2021.1.0.0 (20210630 - Build 21607 - WIN64). Before that Build: 2020.2.3-b20820.
To give you more details & how to imitate
the problem (sry. can't share the workflow):
  • I start a workflow and want to make changes, so I run it to point xy
  • Next I use the Visual Preview from different Transformers
  • I click on the line (in the Visual Preview - Graphics), first all do well
  • After some transformers (Attribute Keeper, FeatureJoiner, Cloner, Tester) no click & no zoom to selected feature is possible any more
  • Every transformers reload for 1-2 sec to load the 17.000 results (maybe here goes something lost after some time?)
connecter
  • Jul 23, 2021 3:32 PM UTC
Hey @kailinatsafe​ ,
I build a workflow (no a meaningful) to show you the bug. Also I record the hole doing:
Bug_FME2Hope that help you. Thanks!
alexvdp
Participant
  • Participant
  • Jan 24, 2023 11:26 AM UTC
Hi @connecter​ and @kailinatsafe​ ,
I'm running into the same issue using an old version of FME (2019.1.2.0).
Can anyone confirm this is an old bug that has been solved in a recent version or is there a workaround for the issue?
Thank you and sorry for opening up an old subject!
connecter
  • Jan 24, 2023 3:52 PM UTC
Hi @alexvdp​ ,
yes, the problem is fixed. It was integrated in version 2022.0.
alexvdp
Participant
  • Participant
  • Jan 24, 2023 7:22 PM UTC
Hi @alexvdp​ ,
Good to know, thanks!
