XMLXQueryExtractor query
  • Jul 11, 2023 3:13 PM UTC
  • 164 views
nielsgerrits
Forum|alt.badge.img+67
Been trying to get this working for a while, but I have to surrender...
My XML:
<?xml version="1.0" encoding="UTF-16"?>
<Surface name="Zone 101_01.01_A_020!" desc="" xmlns="http://www.landxml.org/schema/LandXML-1.2">
<SourceData/>
<Definition surfType="TIN" area2DSurf="234921.542328654672" area3DSurf="238197.012906672346" elevMax="11.943587904916" elevMin="-3.839199295337">
<Pnts>
<P id="2">214609.472108227172 150506.362479594914 5.162708941504</P>
</Pnts>
</Definition>
</Surface>
The attribute I need is "Zone 101_01.01_A_020!".
Queries I tried:
/Surface/@name/string()
for $c in /Surface
return data($c/@name)
/Surface/@name
When I test in online extractors, it does work. When I remove the namespace it starts to work, but why?
I'm using FME Desktop 2021.2.6
Can someone please help?
Best answer by ebygomm
declare namespace x='http://www.landxml.org/schema/LandXML-1.2';
/x:Surface/@name/string()
Forum|alt.badge.img+54
  • Jul 11, 2023 4:05 PM UTC
nielsgerrits
thanks!
nielsgerrits
thanks!
Lesson learned, take more time to read the documentation more carefully, as it is described in the first example. 😅
Since the top-level node contains the namespace declaration 'xmlns', the namespace must be declared in the query and it must be used to specify every element.
