Writing/Updating Metadata from SDE to Shapefile
  • December 2, 2021
  • 125 views
I was following this example to write/update the metadata from SDE.
https://community.safe.com/s/article/working-with-geodatabase-metadata-writing-to-xml
READER features: from SDE
READER metadata: from SDE
WRITER: GENERIC (4 options: SHP, FGDB, DWG, KML)
I was able to write both spatial features and their metadata to FGDB (using ArcGIS Catalog to view both features and metadata).
But when I picked the output as Shapefile, the features were written out with a boundary (for lines, but not for points). E.g. I have a point file with 722 features it will be written as 722 features. If I write a line file with 1000 features then I will end up having 1001 because there is a boundary linework written as one of the spatial features.
Also, the metadata wasn't included in the shapefiles (using ArcGIS Catalog to view).
I try to narrow down the output by having a Shapefile writer only but the same problem persists.
Anyone can shed me some light on this issue? Thanks.
owen
  • December 2, 2021
I dont think you can update shapefile metadata in the same way as a geodatabase. you might need an xml writer to create an xml metadata file for your shapefiles. alternatively you could update the gdb and have a secondary process to write the output to shp
