Writing geometry to PostgreSQL database
  • October 28, 2022
  • 7 replies
  • 230 views
dustin
Forum|alt.badge.img+31
I'm attempting to write data into a PostgreSQL database using the PostGIS writer. The issue I'm having is that the geometry is not being 'drawn' in ArcPro. When selecting the record in the attribute table, the geometry highlights but is not visible. When creating a feature from scratch in ArcPro, it draws as expected. This makes me believe it's a configuration issue within FME.
I have verified the Shape Column is 'shape' (as defined in the database), and that the SRID matches that which is specified as a constraint in the database (3857). The coordinate system I'm using on the writer is EPSG:3857. I'm converting from DGN, if that is relevant.
When reading the data back in with FME, all geometry appears normal and in the correct location.
What could be the issue?
nielsgerrits
Forum|alt.badge.img+54
Does recalculate extent and / or spatial index make the geometry visible?
dustin
  • October 28, 2022
It does not, unfortunately.
f.kemminje
Forum|alt.badge.img+11
  • October 29, 2022
validate the geometry just before writing . use geometry validator transformer.
Sometimes , some geometries are not rendering, because too many points in one location, self intersecting, phantom elements etc...
ctredinnick
Forum|alt.badge.img+18
  • October 30, 2022
I've seen dgn files with extreme Z coordinates which can cause an issue for esri. Try 3D forcing it to 0.
dustin
  • October 31, 2022
Digging into this a little further -
In this database provided by the client, there was existing data in another feature class that appears in the correct location in ArcPro. Note the coordinates in the screenshot:
imageNow I read in that same feature class with FME, along with the feature class I've written into with FME. The coordinates being displayed in FME Data Inspector do not match what is in ArcPro:
imageZooming out in Data Inspector and hovering over the features I created in FME, the coordinates match as expected (where the existing data is being displayed in ArcPro).
imageI feel like this is a projection issue, but it's not making much sense to me at this point.
ctredinnick
  • November 1, 2022
Possibly the data was identified as the wrong coordinate system before you reprojected it? I don't think FME recognises DGN coordinate systems, which could be it too. Use a CoordinateSystemSetter to tell the data what its coordinate system is before reprojecting it. Compare with the existing data like you've done to be sure it comes out in the right place, right coordinate range etc.
dustin
  • November 1, 2022
So, there was a whole host of issues. There were several geometry validation errors, as well as projection issues. I fixed these with the GeometryValidator, and the EsriReprojector, and all is fairly well now 😁 . Thanks @ctredinnick​ and @f.kemminje​ for the suggestions. They helped a lot.
