Writing data to a sde geodatabase (Esri Geodatabase /ArcSDE Geodb), but I got an error: invalid cursor state
  • Dec 21, 2022 4:34 AM UTC
  • 70 views
myfriendtae
Hello all,
I am trying to write some data to my SDE geodatabase(file), and I tried two transformers to achieve my goals:
  1. Feature writer
I got an error: invalid cursor state from the database. When I filtered one row and run the writer, the data were successfully injected, but some of the injected data are different from the intended data. For example, a foreign key needs to be injected as 5 but it's injected as null or 2 in a different row.
Please see the setting below.
  1. Python Caller
I used Geometry extractor to write the shape attribute, Shape@XY with the value (longitude, latitude), and then used arpy.cursor.insurtRow to insert the data under the input function using feature.getAttribute method. I got an error: the INSERT statement conflicted with the FOREIGN KEY constraint.
Thank you,
Tae
@ccctae​ It looks like your trying to write to feature classes that participate in a relationship. Have a look at the article Introduction to Working with Geodatabase Relationship Classes and related articles to understand how FME interacts with Geodb Relationship classes
myfriendtae
  • Jan 19, 2023 7:13 PM UTC
Thank you very much. It's great to know.
