Best Answer
write multicurve/multisurface into GPKG error
  • June 16, 2022
  • 14 replies
  • 225 views
viviancfhung
There are GML/FGDB dataset with "round conner polygon" or multilines geometry which is mixed "curve and lines". It can't be written into GPKG file.
src dataset geometry
image.pngThe output geometry is IFMENull
How can fix it?
Best answer by david_r
Did you try using a generic geometry column in the GeoPackage table? That should work.
Try this:
  • June 16, 2022
It depends on a few factors, but it should be possible. First make sure to use a generic geometry field on the writer. If you're writing to an existing geopackage with a specific geometry type that excludes arcs, you can insert an ArcStroker just before the writer.
You might also want to try using a GeometryRefiner and possibly also a GeometryValidator (OGC checks) to make sure all geometries are valid.
viviancfhung
  • June 23, 2022
Thanks, I will try
viviancfhung
  • June 24, 2022
After GeometryRefiner, we have point, line , polygon, arc, ellipse, surface ...
I use MULTICURVE to map arc, but
What's Geometry type in GPKG can map ellipse?
What's Geometry type in GPKG for surface?
viviancfhung
  • June 24, 2022
I try to use GeometryValidator (OGC checks), It classify all my MULTICURVE geometries or mixture of MULTILINESTRING and MULTICURVE geometries as failed.
Then how can I fix it
  • June 27, 2022
Ellipses and surfaces aren't supported in a GeoPackage, see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/ogcgeopackage/quick_facts_ogcgeopackage.htm
  • June 27, 2022
viviancfhung
  • June 28, 2022
viviancfhung
  • June 29, 2022
I will try, thanks
viviancfhung
  • June 30, 2022
I'm so new for FME. How can I set generic geometry column? Thanks
  • June 30, 2022
Try this:
viviancfhung
  • July 4, 2022
Thanks, I will try
viviancfhung
  • July 5, 2022
  1. Is any way can we convert curve into line. convert round polygon into polygon
  2. our FGDB dataset use MULTISURFACE to define round polygon. Can it be translated to GPKG accurately
  • July 5, 2022
  1. You can use an ArcStroker to convert all the arcs to polyline segments. Sometimes you may also want to add a GeometryRefiner after.
  2. I'm not sure I understand what you mean by "round polygon"... Do you mean an ellipse?
viviancfhung
  • August 2, 2022
Thanks for your help, this setting solve some of my problems. But Now I got this error when use the setting to convert dataset
image...
imageOur geometry Data is this
imagewhat's Non-Cirular Arc.
Is this
