Write many excel files using a counter value in the file name without including the counter as an attribute in the output
Hello!
I have a workbench in FME Desktop 2021.2 where I need to write out several XLSX files from the same dataset, with exactly 1500 rows in each, and each one named FileName_1.xlsx, FileName_2.xlsx, FileName_3.xlsx, etc.
I have managed to do this using a Counter, and ExpressionEvaluator. The ExpressionEvaluator takes the attribute from Counter (_count) and creates a new attribute called "_result" using this expression:
@floor(@Value(_count)/1500) + 1
So that gives me the sequential file numbers that I want to append to the file names based on 1500 rows in each one.
I can do this if I include the "result" attribute in the Excel writer, and use a FanOut Expression like this:
FileName_@Value(result).xlsx
This produces the Excel files with the correct file names, with 1500 rows per file.
However, my question is, how can I exclude this "result" attribute in the Excel files? I don't want that attribute being written out. If I remove it, there is then no attribute for the Fanout expression to operate on.
I thought about putting this "result" value in a variable, but I cannot seem to access this variable in the FanOut Expression. Any help would be appreciated.
Thanks
  • February 2, 2022
@firsttube​ I think you must have Attribute Definition: Automatic set on the Excel Writer Feature Type User Attributes TAB. Switch to Manual and you'll have more control over the attributes you're writing out.
dialog
Forum|alt.badge.img+39
  • February 2, 2022
You don't need to remove the attribute, just make sure it is not defined as an attribute in the writer
  • February 2, 2022
dialog
Thanks @Mark Stoakes​  I do have the Attribute Definition set to Manual.
  • February 2, 2022
Hi @ebygomm​ , please clarify how to "make sure it is not defined as an attribute in the writer"
If I disconnect the "result" attribute, the files don't fanout.
thanks!
mark2atsafe
Forum|alt.badge.img+49
  • February 4, 2022
Huh! I'd be quite shocked if it failed to write any data if the attribute were missing.
I did a very quick video demo here: https://www.screencast.com/t/CmGgjiZS
I hope this helps.
  • February 4, 2022
@firsttube​ This should be working for you. I've attached a small example. I'm using _creation_instance to fan out each file, but _creation_instance isn't written to the spreadsheet (as per @ebygomm​ 's image). Workspace attached (FME 2021.2)
  • February 4, 2022
I hope this helps.
Thank you @mark2atsafe​ !! Your video made me realize that I was using the "result" attribute in the writer for the fanout parameter, but I should have been using the "_result" attribute created in the ExpressionEvaluator.
imageimageOnce I changed the Fanout expression to @Value(_result).xlsx and removed the "result" attribute from the Excel writer, it worked!
mark2atsafe
  • February 7, 2022
Excellent. Glad it's working for you now.
