Write in a PostgreSQL editable view
  • Mar 18, 2021 3:14 PM UTC
  • 17 replies
  • 452 views
rbovard
Hello,
I have an editable view in PostGIS (PostgreSQL) and I'm trying to write in it with FME.
For that, I've:
  • Added my view from a PostGIS reader (to have its structure - and confirm it exists)
  • Duplicated this view in a new PostGIS writer (to keep its structure)
  • Set the table handling as `Use existing`
  • Connected a worflow to end in my view
But when I run the workspace, I'm facing this error:
POSTGIS Writer: Table 'xxx.yyy' does not exist. Please check the Table Name specified, or modify the Table Handling value under Format Parameters
So my question is: is it possible to write in an editable view?
For the record, I can write in my view with another client (QGIS) with the same credentials.
Thanks for any input.
Rémi
@rbovard​ I couldn't reproduce your error, I've attached an example workspace that creates a table, creates a view and then writes to the view. So I suspect permissions or possibly an incorrect view name if you're using a table qualifier.
 Requirements for updateable views.
rbovard
  • Mar 19, 2021 1:59 PM UTC
Thanks @Mark Stoakes​ for your answer and your example.
I'm glad to see FME can write into views, but it still not working on my side.
It's strange because:
  • If I rename my feature type in writer, it creates a new table in my database --> Not a rights issue
  • If I set the writer action as `Create if needed` it shows me `ERROR: relation "my_view" already exists` --> Not a qualifier issue
  • If I set the writer `Use existing` (which I was initially doing), it shows me `Table 'my_view' does not exist.`
Maybe it's something with PostGIS writer? Like I said, I can update my view via other client (QGIS), it also work in pure SQL:
INSERT INTO <schema>.<view>(<geom>)
VALUES (ST_GeomFromText('...'));
Any other idea?
Best regards,
Rémi
Any other idea?
Best regards,
Rémi
@rbovard​ My first example was PostgreSQL so I thought it might be PostGIS that was the issue here. So I created a second example with a PostGIS view (attached). This seems to work OK as well. So I suspect it's the way that your view has been created that is causing FME to stumble.
I think you'll need to share you example (SQL, workspace & sample data)  with the community, or open a support issue with your local FME Reseller. (Please post the resolution answer back here if there is one)
rbovard
  • Mar 26, 2021 3:50 PM UTC
Any other idea?
Best regards,
Rémi
Thanks a lot @Mark Stoakes​ for this second example.
In fact you're still using a PostgreSQL writer and features with lat/lng attributes, but - if I understand it right - they aren't spatial features and you're not writing in a spatial view.
My use case is writing spatial features, in a spatial view via a PostGIS writer.
Is it clearer for you or should I try to give you a basic workspace to illustrate that?
Anyway, thanks again for trying to solve my issue ;)
Best regards,
Rémi
Any other idea?
Best regards,
Rémi
@rbovard​ Sorry, that was my error. I forgot to switch the last, and important, writer to PostGIS. When I do that I reproduce your error. My guess is that there is additional SQL that needs to be called using the GDAL driver to support writing to an editable view (or perhaps when you create the view).
At the moment it looks like FME doesn't support writing to an editable view that has a spatial column.
Revised workspace that reproduces @rbovard​ 's error when writing to a spatial editable view.
rbovard
  • Jun 25, 2021 9:48 AM UTC
Hi @Mark Stoakes​
Do you have any update on this issue?
Thanks in advance for your feedback.
Rémi
@rbovard​ this hasn't changed. I believe that it is the way the view is created. In the attached workspace, , as far as I can tell, the view created is not recognised in QGIS. It returns the error;
Layer is not valid: The layer dbname='ORYX' host=localhost port=5432 sslmode=disable key='"longitude"' srid=4326 type=Point table="public"."cellsignalsGEOM" (geom) is not a valid layer and can not be added to the map. Reason:
If you know how to modify the example in the workspace to create a valid view that QGIS can read then I can try and determine why FME can't read it.
rbovard
  • Jun 29, 2021 10:17 AM UTC
Thanks a lot for your feedback.
I'm not sure it's related to the view creation, since here I can load my view in QGIS but not write in it via FME (it works from QGIS or even pure SQL).
I'll try to create a very basic workspace to demonstrate it.
rbovard
  • Jun 29, 2021 1:32 PM UTC
@Mark Stoakes​ Please find here an attached workspace wich creates a table, then a view and try to write in it.
For the record, the view is editable from QGIS or pure SQL.
rbovard
  • Jul 7, 2021 9:10 AM UTC
@Mark Stoakes​ Is it better with my script? Are you able to load this view into QGIS and edit it?
takacstamas
  • Nov 22, 2023 11:57 AM UTC
@rbovard​ did you find a solution to this problem? That's exactly what I'm facing right now and i cannot find a solution.
rbovard
  • Nov 22, 2023 12:53 PM UTC
Hi @takacstamas​
Unfortunately not.
The workaround I used was to write to a temp table with the same structure as my editable view, and then using a SQL Executor, insert the data with a query of type
INSERT INTO <my_view> SELECT * FROM <my_temp_table>
And then drop my temp table also with SQL.
It wasn't the most straightforward, but it worked. After that, I didn't try with the latest versions of FME, so maybe there have been improvements in that area.
Rémi
jovitaatsafe
Forum|alt.badge.img+11
Hi @rbovard and @takacstamas,
I’m happy to share that an update to FME Form 2024.1 has added the ability to write to a view with a spatial column for PostGIS/PostgreSQL formats thanks to a problem report Mark had filed for the team identified internally as (FMEENGINE-70047).
So far the functionality is just available in FME 2024.1 betas. You can access the beta install here: https://engage.safe.com/support/downloads/#beta
If you have a chance to give it a try, please let us know if you have any feedback on it!
Happy FME’ing!
Jovita
takacstamas
  • Apr 10, 2024 12:55 PM UTC
Hi @jovitaatsafe!
I’m installed the latest version of FME Form 2024.1 Beta (Build 24553) and it work perfectly!
Thank you for resolving this issue, the FME team is the Best!
Tamás
jfav
  • Feb 13, 2026 3:11 PM UTC
I’m experiencing exactly the same issue as @rbovard.
I’m trying to insert data into a PostGIS updatable view, but I encounter the following error:
The PostGIS/PostgreSQL writer does not dynamically create rules for views. INSERT, UPDATE and DELETE queries on views require additional preconfigured rules; otherwise, they are only usable for SELECT queries.
I believe I’m using the same data model as @rbovard. I can edit the view and create new objects directly within QGIS without any problem.
For information, I’m working with FME 2025.1.
Does anyone have an idea what might be causing this issue?
Thanks in advance.
Best regards,
Jérémie
jovitaatsafe
Hi ​@jfav,
I suspect you may have run into a slightly different scenario based on your log error snippet which looks different from the error message in the reported issue we had put out a fix for.
I’d suggest creating a new post for better visibility, and if you’re able provide a bit more context on your workspace, what it’s trying to achieve, and possibly a screenshot of your PostGIS writer parameter configuration, I think the community might be able to chime in with some more ideas on this one.
