Wrapping a standalone python script in python creator
  • Jan 27, 2022 9:31 PM UTC
  • 141 views
cseago
Participant
I am wrapping a standalone python script in a python creator and seem to be running into an issue. The script runs fine when I run it in IDLE. However, I am experiencing an error in my workbench when running the creator.
Error - error - `fme' instance does not have a method `input(self, feature)'. fme.input(self, feature) must be defined.
Script -
# Import system modules
import sys
import string
import os
import arcgisscripting
import logging
import logging.config
class fme:
  def main():
    logging.basicConfig(
     filename=r'\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Common\\Scripts\\NetInj_NatNbr_Clip.log', filemode = 'w',
     format='%(asctime)-6s: %(name)s - %(levelname)s - %(message)s')
    logger = logging.getLogger('NetInjectionClip_log')
    logger.setLevel(logging.INFO)
    try:
  # Create the Geoprocessor object
      gp = arcgisscripting.create()
      gp.overwriteoutput = True
      logger.info("checking out extension")
  # Check out any necessary licenses
      gp.CheckOutExtension("spatial")
      logger.info("checking out successful")
  # Load required toolboxes...
  #gp.AddToolbox("E:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")
  #gp.AddToolbox("E:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
  # Local variables...
      NatNbr_conv_7test = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\SJVBU.NATNBR_CONV_7"
      NatNbr_conv_14test = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\NATNBR_CONV_14"
      NatNbr_conv_7test_clip = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\NATNBR_CONV_7_CLIP"
      NatNbr_conv_14test_clip = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\NATNBR_CONV_14_CLIP"
      tbl_cy_geog_netinj_clip = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\TBL_CY_GEOG_NETINJ_CLIP"
      tbl_cy_geog_netinj_clip__2_ = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\TBL_CY_GEOG_NETINJ_CLIP"
      cy_gisdata_GISPUB_tbl_cy_fac_wls_netinjection = r"\\\\maphub-amer-vfs.azure.chevron.com\\MapHub-NA\\ETL\\FME\\SJV\\TEST\\Projects\\iDOT\\Grids\\SJVBU_SDESJV_TEST.sde\\SJVBU.TBL_CY_FAC_WLS_NETINJECTION"
      logger.info(cy_gisdata_GISPUB_tbl_cy_fac_wls_netinjection)
  #print cy_gisdata_GISPUB_tbl_cy_fac_wls_netinjection
      logger.info("begin Natual Neighbor process")
  # Process: Natural Neighbor...
      gp.NaturalNeighbor_sa(cy_gisdata_GISPUB_tbl_cy_fac_wls_netinjection, "SevenDayAvg", NatNbr_conv_7test, "120")
      logger.info("Natual Neighbor process successful, begin clip")
  # Process: Clip...
      gp.Clip_management(NatNbr_conv_7test, "1499116.31909478 673045.729143351 1507415.60400535 680852.946468517", NatNbr_conv_7test_clip, tbl_cy_geog_netinj_clip, "", "ClippingGeometry")
      logger.info("clip successful, begin Natural Neighbor process2")
  # Process: Natural Neighbor (2)...
      gp.NaturalNeighbor_sa(cy_gisdata_GISPUB_tbl_cy_fac_wls_netinjection, "FourteenDayAvg", NatNbr_conv_14test, "120")
      logger.info("Natual Neighbor process2 successful, begin clip2")
  # Process: Clip (2)...
      gp.Clip_management(NatNbr_conv_14test, "1499116.31909478 673045.729143351 1507415.60400535 680852.946468517", NatNbr_conv_14test_clip, tbl_cy_geog_netinj_clip__2_, "", "ClippingGeometry")
      logger.info("clip2 successful")
  #print("success")
    except:
      logger.exception("job failed")
      print("failed")
    finally:
# Check in any necessary licenses
      gp.CheckInExtension("spatial")
fme.main()
Thanks in advance!
  • Jan 27, 2022 10:31 PM UTC
Hi @cseago​ , you have to define a class according to the "Template Class Interface" which is predefined in PythonCreator (see the screenshot). Once the translation has started, FME generates an instance of the class specified in the "Class to Process Features" parameter and calls its "input" method. You therefore should implement the "input" method so that your own script will be executed.
pythoncreator-template-class-interface
