Would like to automate a gps to CAD process. How do I start?
  • September 5, 2020
  • 70 views
jcmichelsen1
I have a process I would like to automate.
Every week I go out into the field and collect gps locations with a few attributes. I export the gps locations as a .gpx file. I open the .gpx file in Google Earth to visually verify the data. I save place as a .kml file. I convert the .kml file to an AutoCAD .dwg file using FME.
Does anyone else do something like this?
Hardware used:
Motorola Moto g7 phone running Android 10 OS
Lenovo T495 Laptop running Windows 10 OS
Applications used:
US Topo Maps app on phone
Google Earth Pro 7.3.3.7786 (64-bit)
FME Desktop 2019.2 FME(R) 2019.2.3.1 (20200212 - Build 19823 - WIN64)
AutoCAD LT 2021
Best answer by takashi
Hi @jcmichelsen1​ , since FME supports reading GPX format and writing AutoCAD format, I think you can create an FME workspace to read features directly from the GPX file, validate them and then write them into an AutoCAD dataset.  See also these pages to learn more about the reader/writer.
GPS eXchange Format (GPX) Reader/Writer
Autodesk AutoCAD DWG/DXF Reader/Writer
  • September 6, 2020
Forum|alt.badge.img+49
I agree with @Takashi Iijima​, you can take out the step where you save as KML from Google Earth, that's not necessary. In fact, you may even find that doing your visual inspection in the FME Data Inspector is a good alternative (but it depends on whether or not the freely available base maps are suitable for your purpose).
drc43
Forum|alt.badge.img+11
  • September 8, 2020
I would also add that you can build your validation and inspection directly into your workspace. If you are always collecting data in the same geographic area (eg. city), you can set up the workspace to verify that all your GPS coordinates fall within this area. Also, in addition to the AutoCAD writer, I would probably add an HTML writer for visual inspection as well. Using an HTMLReportGenerator, you can create a basic webmap showing your GPS points against a background map like Esri's imagery. This then gives you a quick map to pull up to visually inspect your data.
