Why does Microsoft Defender for Cloud raise a warning when an SQLExecutor is run on an Azure SQL-database?
  • Apr 11, 2022 5:31 PM UTC
  • 196 views
torbjornd
Forum|alt.badge.img+5
I'm running a workbench which contains several SQLExecutors that queries an Azure SQL database. When running the workbench we get an alert from Microsoft Defender for Cloud saying that "An application generated a faulty SQL statement on database XXX. This may indicate that the application is vulnerable to SQL injection".
When looking into the case, I can see that the query raising this warning is from FME:
SELECT * INTO #fme_tempAdoDataTypeTable_spatialReader FROM ( select CustomerID, Name, PostAddress_Address1 from Customer where UPPER([Name]) = 'Hans Hansen' and UPPER(PostAddress_Address1) = 'Gates' vei 69' ) AS customQuery WHERE 1=0
Does anyone now why this warning occurs? Is it normal that FME triggers these?
geomancer
Forum|alt.badge.img+71
  • Apr 12, 2022 7:54 AM UTC
'Gates' vei 69' looks to be faulty.
Aside from this: both UPPER([Name]) = 'some string with lowercase characters' and UPPER(PostAddress_Address1) = 'some string with lowercase characters' will never return any results, but those are not a syntax errors.
