Where to put a custom projection file
  • Apr 27, 2021 7:54 AM UTC
  • 270 views
Hi, I have created a custom projection file and put it in User -> Document-> FME -> CoordinateSystems
I have restarted my laptop. It does not appear in the gallery.
I created it with a text editor.
Am I putting it in the correct location for FME 2020?
Is there a log somewhere to tell be if it has been read or there is an error in the file?
Do I need the backslash on the end of each line?
I was hoping to use the online tool to create the projection but I wanted to base the projection on GDA2020 , There does not appear to be a Datum to reference for 2020 in the dropdown in the online tool.
Any assistance welcomed,
Ian Hamilton
Best answer by ian2016
I have discovered the error of my ways. There were colons after each identifier, which is not the correct format. I also added quotes to the SOURCE and DESC_NAME - not sure if that changed anything. The only way I got any feedback when starting up FME was because I had inadvertently another syntax error in the file which was grave enough to get a popup error message. Now resolved, thanks.
itsmatt
Forum|alt.badge.img+48
  • Apr 27, 2021 8:17 AM UTC
Hmmm, seems that GDA2020 isn't listed here in the list of predefined datums: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/CoordSys/Predefined_Datums.htm
I suspect that if you are using this as your datum in the .fme file that this could be why. As a test you could try renaming the datum to something in the list to see if it then pops up.
It's a little off though because it's quite clear that GDA2020 is used in FME - possibly just a small bug?
Perhaps @daveatsafe​ knows more
  • Apr 28, 2021 1:31 AM UTC
Thanks for your answer, following on from the above,
This is my projection information, I have created a file SSGH_Projection.fme and put it in both a shared folder I created and also in the User -> Document-> FME -> folder . (I also tried to edit the Reproject definitions file but it appears I don't have the rights to do that.)
As far as I can tell neither of these locations are being read as the projection does not appear in the projections gallery. ( I tried the above suggestion and set the datum to gda94 to see if anything would be different - nothing changed. Am I doing something stupid here?
CS_NAME: SSGH\\
DESC_NM: Snowy Surface Grid High Zone 55 (GDA 2020)\\
DT_NAME: GDA94\\
EPSG: Unknown\\
GROUP: AUSNZ\\
MAP_SCL: 1\\
MAX_LAT: -9.23\\
MAX_LNG: 150.01\\
MIN_LAT: -50.89\\
MIN_LNG: 144\\
PARM1: 148.5333333\\
PROJ: TM\\
QUAD: 1\\
SCL_RED: 1.000227\\
SOURCE: Snowy Hydro Project\\
UNIT: METER\\
X_OFF: 650000\\
Y_OFF: 4300000\\
ZERO_X: 0.001\\
ZERO_Y: 0.001
  • Apr 28, 2021 1:59 AM UTC
