We have two formats to connect with SQL Server :
What is the difference between them?
The format is exactly the same, it's just the connection method that differs. The non-JDBC connection uses Microsoft ADO to connect to the database, which I believe is only available on Windows.
See also https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/mssql_ado/mssql_ado.htm
Already have an account? Login
