Using PointOnAreaOverlayer, I would like to know how to extract polygon IDs and assign them to corresponding points that are within each polygon.
  • Jan 4, 2023 11:16 PM UTC
  • 84 views
Best answer by geomancer
Under Attribute Accumulation enable Merge Attributes. All attributes from the polygons will be copied to the points that are within that polygon.
POAO_Merge_AttributesIf you have overlapping polygons, enable Generate List On Output 'Point', and enter the appropriate settings.
geomancer
Forum|alt.badge.img+71
  • Jan 5, 2023 6:39 AM UTC
  • Jan 5, 2023 4:26 PM UTC
It worked! Thank you so much.
