Using Choice multiple paramater in an SQL executor where statement
  • Jan 28, 2021 1:54 PM UTC
  • 188 views
andrewj74
Forum|alt.badge.img+8
i am trying to pass some values from a choice multiple into an sql executor as a published parameter ('$(Name)'). I can get it to work by using something like this but its not very efficient.
select Name
from Nametable
where
 '$(Name)' LIKE '%'+ columnName +'%'
i have done this manually: where columnName in (Andrew, David)
It works alot faster than the above but i cant get it to populate and run from the published parameter.
this wont work columnName =  '$(Name)' as it translates into
columnName = 'Andrew David' so there will never be a match as the name in column will be Andrew or David.
Any help or pointers would be appreciated.
Thanks,
Andrew
Forum|alt.badge.img+54
  • Jan 28, 2021 2:03 PM UTC
You probably need to do some manipulation of the parameter returned, so use a ParameterFetcher to get your parameter into an attribute then a string replacer to replace the space with a comma (if your choices have spaces in them it gets a bit more complicated) You can then use the attribute in the sqlexecutor
andrewj74
  • Jan 28, 2021 2:39 PM UTC
yeah i did think that but was trying to avoid adding transformers etc as i have quite a few parameters i want to pass in. Some of them have spaces in them so its a bit complicated. It would be a useful feature to be able to pass them in as a list directly from the published parameter.
tomf
Forum|alt.badge.img+31
  • Jan 29, 2021 12:59 AM UTC
Another option would be to create another (private) parameter for each list parameter you need to pass in, using the Python type and manipulate the space-separated string from the Published parameter into a comma-separated string you can reference in your SQL statements. Still more work than ideal, but at least there's no "extra" transformers 😉
I've suggested this as an idea for future improvement — visit https://community.safe.com/s/idea/0874Q000000j0RiQAI/detail to vote on it
gio
Forum|alt.badge.img+15
  • Jan 29, 2021 11:03 AM UTC
@andrewj74​
Indeed use a scripted parameter to read the choice parameter.
You can then peel off the choice. I use tcl for that; of course regexp.
As @tomf​  suggests, though o leave the "In String" building to the workspace (the custom you see in the 2nd pic. Reason is this wokspace (built in 2016 en upgraded to 2018) is called (WSC) which seems to prevent the private parameter to execute.
Have not upgrade d it to latest verion.
And then acces it in the workspace.
Some pics from a workbench that applies this massively,
to illustrate the idea:
Choice pub parameter
Private Para aquire choice from pub parameter
