Using AttributeManager to update attributes in the Writer from matching records from the Reader. Takes a long time. 6 hours for 86,000 records. Is this normal?
  • February 1, 2023
  • 12 replies
  • 29 views
Using AttributeManager to update 86,000 (existing) records using APN for key. Is this process optimized by FME? It takes a long time, and I assume it is N*N time. (Does the Reader iterate through each record, one at a time, then searching through all the records in the Writer to find the matching key?)
Forum|alt.badge.img+62
Can you post a screenshot of your workspace? Specifically, how are you doing the matching?
  • February 1, 2023
Here is screen shots. Parameters on the Writer:
Feature Operation: Update
Table Handling: Use Existing
Update Spatial Column(s): No
Match Columns: parcel
or
WHERE Clause: "parcel"='@Value(parcel)'
or
I suspect that since parcel is unique for every feature you're essentially sending 86000 queries to that geodatabase. Have you tried the match columns option and if so, does that go faster?
  • February 1, 2023
Will try the match column option on file geodatabase, and report back here when done.
  • February 2, 2023
Here is result, using a file geodatabase on a network path, e.g. \\\\server1\\GISData\\FMEData.gdb
Translation was SUCCESSFUL with 12 warning(s) (86652 feature(s) output)
FME Session Duration: 6 hours 55 minutes 2 seconds. (CPU: 7387.8s user, 15737.0s system)
END - ProcessID: 25168, peak process memory usage: 206772 kB, current process memory usage: 109080 kB
  • February 2, 2023
Here are the warnings. Maybe I need to adjust for this? (Feature Caching is ON?)
The workspace may run slower because features are being recorded on all output ports.
No rows matched UPDATE query to table/feature class 'OwnerInfo_TEST' where parcel = N'231232020'
No rows matched UPDATE query to table/feature class 'OwnerInfo_TEST' where parcel = N'151380055'
No rows matched UPDATE query to table/feature class 'OwnerInfo_TEST' where parcel = N'172390006'
No rows matched UPDATE query to table/feature class 'OwnerInfo_TEST' where parcel = N'215231016'
No rows matched UPDATE query to table/feature class 'OwnerInfo_TEST' where parcel = N'146141078'
-~ Feature caches have been recorded at every stage of the translation. ~-
-~ To inspect the recorded features, ~-
-~ click the feature cache icons next to the ports. ~-
Feature caching off will definitely improve performance, but if you have a lot of those warnings I’d check to see if the parcel numbers are correct.
  • February 2, 2023
There were only those five mismatches, and expected. I will be able to try without feature caching later today. Thank you.
Ok, the other thing I noticed is that the system time is very high compared to the cpu time. System time is when FME needs to wait on something, like a database across a slow network. Are you able to copy the geodatabase to your local drive and try that?
  • February 2, 2023
Yes. I will use a local Windows drive (using a SSD).
  • February 3, 2023
Here is results: a little less overall time, but still a lot of system time. I'm curious enough to try on C:\\ instead of D:\\ and will post results on Monday. (Those 5 warnings are the expected non-match records).
Translation was SUCCESSFUL with 5 warning(s) (86652 feature(s) output)
FME Session Duration: 5 hours 20 minutes 56.8 seconds. (CPU: 7000.0s user, 12215.5s system)
END - ProcessID: 17056, peak process memory usage: 256780 kB, current process memory usage: 109360 kB
  • February 3, 2023
Here are more results using local C:\\ drive, slightly slower than D:\\ (but I was also working on other things at same time).
FME Session Duration: 6 hours 8 minutes 29.9 seconds. (CPU: 7508.1s user, 14629.1s system)
END - ProcessID: 19268, peak process memory usage: 256484 kB, current process memory usage: 109056 kB
