Trigger a Reader only if condition is met
  • Nov 3, 2022 6:38 AM UTC
  • 320 views
robertr
Hello,
I have a workbench that checks several files for some data mergers. Problem is, this one source I have (30+ excel files with thousand of rows each) is useful only when there is a certain value in one of the columns.
I was wondering if there is a way to open these files only if a condition is met beforehand (like a user parameter prompt). I wouldn't want to read all files every time knowing that if the condition is not met, they won't bring any value to the end result.
For example, If I chose at the start of the workbench "Toronto" - it should trigger this reader; if I chose some other city, it shouldn't.
Any advice is appreciated. Thanks!
  • Nov 3, 2022 7:40 AM UTC
Using a FeatureReader transformer rather than the "classic" reader will allow you to do some pre-processing and decide whether to trigger it or not.
f.kemminje
Forum|alt.badge.img+11
  • Nov 3, 2022 8:15 AM UTC
As David said, you can test the user parameter value, and if satisfied, then read excel.
here is the w bench file
robertr
  • Nov 3, 2022 1:12 PM UTC
thank you @f.kemminje​ - really easy to follow and implement.
robertr
  • Nov 3, 2022 1:13 PM UTC
thank you @david_r​
I don't know how I did not think of this. Much appreciated.
