Translate from FGDB to Shapefile failed
  • Dec 9, 2022 9:18 AM UTC
  • 8 replies
  • 115 views
viviancfhung
I'm try to translate fgdb to shp file But I got following error
BADNEWS: File C:\\Program Files\\FME\\metafile\\MULTI_WRITER.fmf could not be opened
(C:\\code\\fme\\foundation\\framework\\control\\generiz.cpp:1658) class StatusInfo *__cdecl STFGenericizer::processMetafile(const class stk::ex::UString<0> &,const class stk::ex::UStringArray<0> *,const class stk::ex::UString<0> &,const class stk::ex::UString<0> &,const class stk::ex::UString<0> &,const class stk::ex::UString<0> &,class STFAttributeName &,class STFMetaMapper &,class STFObjectNameConstraints &,bool &,bool &,bool &,class stk::ex::UStringArray<0> &,class stk::ex::UString<0> &,class std::vector<class STFFeatureType,class std::allocator<class STFFeatureType> > &,class stk::ex::UStringArray<0> &,class stk::ex::UStringArray<0> &,class stk::ex::UString<0> &,class std::vector<struct std::pair<class STFAttributeName,class stk::ex::UString<0> >,class std::allocator<struct std::pair<class STFAttributeName,class stk::ex::UString<0> > > > &,class stk::ex::UStringArray<0> &,class std::vector<class STFAttributeName,class std::allocator<class STFAttributeName> > &,class stk::ex::UStringArray<0> &,class stk::ex::UStringArray<0> &,bool &,bool &,class stk::ex::UString<0> &,class stk::ex::UStringArray<0> &,class STFObjectNameConstraints &,class stk::ex::UString<0> &,class stk::ex::UStringArray<0> &,class stk::ex::UStringArray<0> &,class stk::ex::UString<0> &)
(C:\\code\\fme\\foundation\\framework\\control\\generiz.cpp:885) class StatusInfo *__cdecl STFGenericizer::loadMetaMapper(const class stk::ex::UString<0> &,const class stk::ex::UString<0> &,const class stk::ex::UStringArray<0> *,const class stk::ex::UStringArray<0> *,bool)
(C:\\code\\fme\\foundation\\framework\\control\\generiz.cpp:5498) class StatusInfo *__cdecl STFGenericizer::getFeatureTypeConstraints(const class stk::ex::UString<0> &,class STFObjectNameConstraints &)
Error running translation.
kailinatsafe
Forum|alt.badge.img+24
Hello @viviancfhung​, thanks for posting. I have some additional questions for you:
  1. What version of FME Desktop you're currently using? You can find this information in FME Desktop > Help > About FME Workbench.
  2. Is this a new workspace or was this an existing one that used to work?
  3. Are you using GenerateWorkspace to create the workspace?
It may be helpful if you can share a sample workspace or input dataset as well. Best, Kailin.
viviancfhung
  • Dec 15, 2022 1:59 AM UTC
Thanks Kailin,
  1. we are using FME desktop 2022.0.0.1(20220505 build-22339 win64)
  2. The workspace is an existing one that used to work
  3. we create workspace manually
The dataset is too large, can't upload. Sorry
viviancfhung
  • Dec 15, 2022 2:05 AM UTC
We found another problem dataset
evieatsafe
Forum|alt.badge.img+28
  • Dec 17, 2022 12:25 AM UTC
Thanks Kailin,
Hi @viviancfhung​ what version of FME did this used to work? I've never seen this error before, but I'll try to reproduce this with the data you have provided.
Edit: I've tried to reproduce your issue in 2022.x without success.
viviancfhung
  • Dec 19, 2022 2:42 AM UTC
Thanks, waiting for your answer
evieatsafe
  • Dec 19, 2022 8:38 PM UTC
@viviancfhung​ What version of FME did this used to work? What reader are you using? Are you able to read in your file with the Esri Geodatabase (File Geodb Open API) reader?
I was not able to reproduce your error as I was able to read in the data fine in 2022.x
viviancfhung
  • Dec 22, 2022 1:53 AM UTC
It's the same FME.
Yes, we can read it by Esri Geodatabase(File Geodb Open API) reader.
We can try it in another FME version again.
Thanks
giovannizappile
Participant
This Hong Kong traffic data contains both line and point data with different columns/fields.
using OPEN API gbd will generate a reader per sign type:
IF you want all together you need to standardize and merge them (POINTS WITH POINTS, LINE WITH LINES) or simply convert each to a single shapefile.
