Transfor Date String from 'YYYY-MM-DD' to Date String 'DD/MM/YYYY'
  • Apr 21, 2023 6:38 PM UTC
  • 5 replies
  • 465 views
galigis
Forum|alt.badge.img+22
HI All,
Any workaround to convert a date string (YYYY-MM-DD format) to DD/MM/YYYY ? The field type needs to stay as date string see below:
I've tried a few transformers (StringReplacer + ListExploder+ String Concatenator) but couldn't get it to work and show 21/04/2023
Thanks
connecter
Forum|alt.badge.img+10
  • Apr 23, 2023 6:07 PM UTC
Hi @galigis​ ,
Have you already tried the DateTimeConverter with the following settings?
galigis
  • Apr 23, 2023 7:14 PM UTC
Thanks @connecter​ - Yes, I have but fme gives me a rejection code 'INVALID_INPUT', see below:
hkingsbury
Forum|alt.badge.img+73
  • Apr 23, 2023 8:32 PM UTC
Before you pass the features into the DateTimeConverter, what does fme show the value to be? I'm wondering if ArcGIS is doing some conversion when showing the date
galigis
  • Apr 24, 2023 7:18 AM UTC
Hi @hkingsbury​ - FME shows the Model_Date as 'YYYY-MM-DD' as string and ArcGIS is also treating the fields as string.
Over the weekend I came up with the solution, maybe isn't the most elegant workaround ever....but does the job :),
Here are the transformers used:
1- StringReplacer to replace '-' to '/'
2- AttributeSplitter to split filed by '/'
3- ListExploder
4-Sorter to sort the list values
5- (3) Testers to filter the element_indexes (day (2), month (1), year (0))
6- AttributeCreator to create 'Day', 'Month', 'Year' fields.
7- Feature Merger to join Day & Month by OBJECTID.
8- Feature Merger to join Month & Year by OBJECTID.
9- StringConcatenator to concatenate day, month, year
10- AttributeKeeper to keep the most important fields.
Any better workaround, please let me know! 🙂
Thanks
hkingsbury
  • Apr 25, 2023 8:08 PM UTC
Based on the above, you should be able to use the solution provided by @connecter​ .
Can you provide a sample of the data?
