Text Editor display issue - Characters disappearing when selecting text
  • Aug 16, 2020 11:14 PM UTC
  • 53 views
pauldowlling
Forum|alt.badge.img+5
Recently text selection in the Text Editor is highlighting characters in a bizarre manner. This happens when I am on a laptop that has multiple monitors attached.
It selects text fine if I am using FME on my laptop screen but when FME is being used on one of the larger monitors, characters disappear whilst highlighting several characters.
FME Text Editor selecting on monitor
Whereas when I select it on laptop screen it looks like this. How it should be.
FME Text Editor selecting on laptop
It also opens up like this without selecting anything
FME Text Editor on monitor
pauldowlling
  • Aug 17, 2020 12:59 AM UTC
It appears a workaround is to set the monitors and laptop screen all to the same resolution and scaling.
Workable but a little awkward having a 15 inch laptop monitor set to the same as two 24 inch monitors.
I am using windows 10 and FME 2018.1 64 bit
  • Aug 17, 2020 7:39 AM UTC
I would also make sure that you have upgraded the display drivers to the latest version. I frequently use separate monitors with differing resolutions, no issues with either FME 2018, 2019 and 2020.
pauldowlling
  • Aug 18, 2020 4:25 AM UTC
Hi David,
Good suggestion. I will speak to my work's ICT team to see if they can do that
