Summarize events from Google Calendar - combine data that is split across multiple lines into 1 line
  • Apr 2, 2023 7:59 PM UTC
  • 75 views
bozboswell
Forum|alt.badge.img+7
I am trying to summarize Google Calendar events from the text output of Google Calendar. The export breaks the Description attribute across multiple lines (kinda like a permanent word wrap). Do you know of any way to walk through a text file and put relevant text back together (anti-word wrap)? I realize there is a Google Calendar reader but we are having some issues with connecting using 2FA. I was hoping the text output would allow me to get around fighting with the Google connection.
For example, I want to eventually get the DESCRIPTION into 1 line: DESCRIPTION:Training Document Rollout\\n\\n-::~:~::~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~::~:~::-\\nJoin with Google Meet: https://meet.google.com/we-m2dbz-xvc\\nOr dial: (US) +1 443-23471-4874 PIN:8were6975#\\nMore phone numbers: https://tel.meet/wje-mebz-xvc?pin=2freaag3037362148&hs=7\\n\\nLearn more about Meet at: https://support.google.com/a/users/answer/912345620\\n\\nPlease do not edit this section.\\n-::~:~::~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~:~::~:~::-
Here is an example of the text output from Google Calendar:
BEGIN:VEVENT
DTSTART:20220520T193000Z
DTEND:20220520T200000Z
DTSTAMP:20230331T151052Z
UID:0j3rr18m741qn7vt@google.com
X-GOOGLE-CONFERENCE:https://meet.google.com/wje-mebz-xde
CREATED:20220516T192256Z
 t: https://meet.google.com/we-m2dbz-xvc\\nOr dial: (US) +1 443-671-4874 PIN:
 867846975#\\nMore phone numbers: https://tel.meet/wje-mebz-xvc?pin=2freaag30373
LAST-MODIFIED:20220516T193817Z
SEQUENCE:0
STATUS:CONFIRMED
SUMMARY:Test
TRANSP:OPAQUE
ATTACH;FILENAME=Notes - Test;FMTTYPE=application/vnd.google-apps.document:h
 ttps://docs.google.com/document/d/1pnawrTurAaSJDnVuy-7RFasdrrgaaweqweqweddspddYR8GzI0n23
 WAs/edit
END:VEVENT
  • Apr 3, 2023 10:18 AM UTC
Due to the complexity of the format, I suspect the easiest is to use a PythonCaller and the iCalendar module to parse the events into FME features. To install the module from the command line:
fme.exe python -m pip install icalendar
I've attached a workspace template (FME 2020.2) that shows how to use the iCalendar module to parse all events into separate FME features:
import fme
import fmeobjects
from icalendar import Calendar, Event
class SplitEvents(object):
    def __init__(self):
        pass
    def input(self, feature):
        calendar_contents = feature.getAttribute('file_contents') or None
        if calendar_contents:
            cal = Calendar.from_ical(calendar_contents)
            for component in cal.walk():
                if component.name == "VEVENT":
                    new_feature = feature.clone()
                    props = component.property_items()
                    for prop in props:
                        name = prop[0]
                        value = component.decoded(name, default='')
                        if isinstance(value, bytes):
                            value = value.decode()
                        new_feature.setAttribute(name, str(value))
                    self.pyoutput(new_feature)
    def close(self):
        pass
