String Concatenator not outputting single result?
  • Sep 27, 2023 6:45 PM UTC
  • 90 views
parke372
Forum|alt.badge.img+11
Hi, I have 2 attributes that are text from a pair of text files, i want to combine them into a single attribute.
I'm using an attribute text file readers to pick out the text, then creating an attribute for each of the text_line_data ouputs and naming them initial (first file contents):
imageFirst string contents:
  THE FIRE TROUBLE CIRCUIT IS REPORTING A MALFUNCTION!
3
and extended (second file contents - second file's filename is contained inside the first file, hence the extra processing):
imageSecond file contents:
THIS INDICATES A MALFUNCTION OF THE FIRE SYSTEM
MONDAY THRU FRIDAY, 8:00 TO 4:30 PM, PLEASE NOTIFY Bob
MAINTENANCE DISPATCH AT XXX-XXXX
ALL OTHER TIMES, NOTIFY THE TELEPHONE OPERATOR.
i'm then using stringconcatenator to combine the two file's contents with a new line between:
imageMy expected result here would be - _results looking something like:
 ****************************************************************************** 3
 but i'm getting them as separate outputs:
not sure where i am going wrong here?
Best answer by churchfraser
The StringConcatenator works by joining two fields within the same feature, rather than across features.
You could adapt your workspace by simply adding a FeatureMerger (Requestor =1, Supplier=1) right before your StringConcatentor. This will combine your two features into one feature, which can then be concatenated. imageimageNote that you may have to insert two New Lines into your StringConcatenator to emulate the above line break.
churchfraser
Forum|alt.badge.img+5
  • Sep 27, 2023 10:24 PM UTC
parke372
  • Oct 3, 2023 4:59 PM UTC
oooooh. that would explain it. thanks, that worked perfect!
