Straight corner after buffer polygons
  • Feb 16, 2023 12:10 PM UTC
  • 465 views
Hi Guys,
Right now I'm messing around with getting the corners sharp again after a positive buffer and back to negative.
What I have is a polygon with small lines, I want to buffer it, so the small lines will be gone after I do again a buffering.
So the first buffer is 5 meters, and the second one is -5. In the first buffer i get straight corners, but when I do the -5, I get rounded ones.....
See picture :
MicrosoftTeams-image (3)
What can I do so I get the straight lines back?
Best answer by tomfriedl
This works:
End Cap Style: Square
Corner Style: Mitter
Miter limit: 90
interpolation Angle:90
Buffer Mode: Precise
tomfriedl
Forum|alt.badge.img+14
  • Feb 16, 2023 12:57 PM UTC
This works:
Miter limit: 90
  • Feb 16, 2023 1:24 PM UTC
Yes, that works! Thanks a lot.
