Split dataset into two streams. One, where points at shared locations. Two, where points are the only ones there.
  • Jan 23, 2024 10:05 AM UTC
  • 6 replies
  • 103 views
scarter
Forum|alt.badge.img+10
Hello Community,
I have a points dataset containing 17 records. Some at stacked at shared locations. Some are isolated in one location…
 SwkPoints1
I need to separate this into two different streams.
Stream one: all records that are at shared locations (i.e: sharing an XY co-ordinate pair)…
SwkPoints2_2
Stream two: all records that are the only records at that location…
 SwkPoints3
 How is this achievable?
Thanks,
geomancer
Forum|alt.badge.img+71
  • Jan 23, 2024 10:41 AM UTC
I assume you determine uniqueness by the value of 'House'.
Use a StatisticsCalculator to count the number of times 'House' occurs, followed by a TestFilter to differentiate between features where 'House' occurs one time (stream two) and features where 'House' occurs more than once (stream one).
scarter
  • Jan 23, 2024 10:46 AM UTC
Sorry, no, I should have stated in my post. The uniqueness is the location. So, it would be based on the X and Y co-ordinates pair. Thanks, Stuart
geomancer
  • Jan 23, 2024 11:06 AM UTC
Create a new attribute (X_Y), and use that attribute in the StatisticsCalculator (both 'Group By' and 'Statistics to Calculate').
Unique
scarter
  • Jan 23, 2024 11:42 AM UTC
Unique
Thanks for that. I'll give it a go.
scarter
  • Jan 23, 2024 12:14 PM UTC
Unique
Hi geomancer, That has worked perfectly. I can now apply this to the real data and connect to the rest of the workspace. Thank so much. Regards.
geomancer
  • Jan 23, 2024 12:21 PM UTC
Unique
Hi Stuart, you're welcome. Good luck!
