split city gml by location
  • Dec 6, 2021 9:07 AM UTC
  • 63 views
abinash
Hello,
I want to split my citygml file into two by referring to a shape file which is an area.
Forum|alt.badge.img+63
You can use either a Clipper transformer (with the shapefile as the Clipper feature) or a FeatureReader with the initiator filled by the shapefile and the spatial filter set to Bounding Boxes Intersect (probably followed by a Clipper, because intersecting bounding boxes doesn't necessarily mean the features intersect as well)
