Split a column into two
  • February 13, 2022
  • 8 replies
  • 363 views
Newbi question, if i have a table where i want to splitt a collumn into two how woud I do that.
Existing format
Column a , Column B, Column C
Index,0,0
2022-01,100,245
2022-02,101, 145
2022-03, 90, 200
North,0,0
2022-02,23, 123
2022-03,35,250
South,0,0
2022-01,87,100
Now I need to isolate the column a and the heading values, Index, North, South and make a new column
Column a , Column B, Column C, New Column
Index,0,0,index
2022-01,100,245, index
2022-02,101, 145, index
2022-03, 90, 200, index
North,0,0, north
2022-02,23, 123, north
2022-03,35,250, North
South,0,0, South
2022-01,87,100, South
The source can be an excel or a db table. Target is a db table
How do I do that?
Best answer by chrisatsafe
Hi @danketil​ ,
Just to make sure I have this right, essentially you want to take the value from Column A and set it on the following columns until it changes from Index to North/South/etc?
2022-02-14_13-46-23 If so, you can get this done using the adjacent feature handling feature in the AttributeManager. Since adjacent feature handling requires the attribute to already exist, you'll first need to use an AttributeCreator or AttributeManager to create column D. Then, in an AttributeManager set the number of prior features to 1 and set the following conditional value for column D.
2022-02-14_14-02-57I've attached a sample workspace and dataset in case that helps. From there, you can write it out to whatever format you'd like. Simply type the name of the format or use the add writer button and connect it to the AttributeManager.
Output:
2022-02-14_14-06-45
chrisatsafe
  • February 14, 2022
Hi @danketil​ ,
Output:
2022-02-14_14-06-45
danilo_fme
Forum|alt.badge.img+53
  • February 15, 2022
Hi @danketil​ ,
Output:
2022-02-14_14-06-45
Great Job @chrisatsafe​
  • February 16, 2022
Hi @danketil​ ,
Output:
2022-02-14_14-06-45
chrisatsafe
Sorry for my late reply, yes that is correct
  • February 16, 2022
I tried your solution but it only works for the first row, it does not replicate the value Index for all rows
  • February 16, 2022
Hi @danketil​ , I got this table from @chrisatsafe​ 's workspace. Isn't this your desired one?​
result
  • February 17, 2022
imageThis is how the model now looks
and below you find the dataset from query
imageAs you can see it is correct for the first row but it does not apply teh rule for the rest of the rows
  • February 17, 2022
Your conditional value setting seems to be wrong. I think it should look like this.conditional-value-setting
  • February 18, 2022
Thanks I figured out what I did wrong. Now it works.
