SOLVED: Web Service Authentication: Browser does not support JavaScript?
  • Jan 4, 2021 5:44 PM UTC
  • 151 views
I am attempting to authenticate my Google v4 API, and run into the following:
temp1My browsers (including default) have JavaScript running and enabled. What do I need to do to allow FME to use it?
Thanks,
Sean
  • Jan 4, 2021 6:02 PM UTC
It turns out, this issue did not have anything to do with JavaScript. I had this window pop-up when I clicked on an account that the program had saved credentials for.
Removing the account, and simply re-adding it, I was able to authenticate without issue.
