[Solved] Export attributes and value from JSON that are not in the documentation for the output but exists in the query
  • February 15, 2021
  • 7 replies
  • 59 views
ronnie.utter
Forum|alt.badge.img+11
Edit: The DateTime did exist in the output in the "Time" attribute as a ISO8601 format.
Problem.
I want to add starttime and endtime as attributes to the export.
I have a working simple workspace that reads a JSON from:
https://earthquake.usgs.gov/fdsnws/event/1/query?format=geojson&starttime=@Value(date_sub)&endtime=@Value(date)
where starttime (value) and endtime(value) are in the format "yyyy-mm-dd" and is created as FME parameters.
The string original looks like this
https://earthquake.usgs.gov/fdsnws/event/1/query?format=geojson&starttime=yyyy-mm-dd&endtime=yyyy-mm-dd
I am exposing the attributes I want with attribute exposer and it works at it should according to the documentation "GeoJSON Summary Format (usgs.gov)"
The starttime and endtime attributes is the date window where I want to read the event data from USGS.
So I guess there is timedata from the earthquake event that stores the date when its monitored. That is the data and time I want to get.
Best answer by ebygomm
ronnie.utter wrote:
I was not able to convert the time with the default DateTimeConverter transformer but I found a custom transformer that worked fine and then i added DateTimeConverter to get %y%m%d format.
I could probably tweak the python code to fix the date it without the DateTimeConverter. But this solution works fine and I am happy for now.
Thank you all. !!!
The DateTimeFormatter should work as long as you divide by 1000 first, and the s in %s must be lowercase
Capture
nielsgerrits
Forum|alt.badge.img+54
In the FeatureReader, set Attribute Accumulation Mode from "Only Use Result" to "Merge Initiator and Result".
2021-02-15_16h49_41
ronnie.utter
  • February 15, 2021
2021-02-15_16h49_41
Hello,
Thank you for your answer. I edit my question since I understand I put it wrong.
Your answer is correct due to my question.
But now i have adjust my question with this lines.
So I guess there is time data from the earthquake event that stores the date when its monitored. That is the data and time I want to get.
Forum|alt.badge.img+38
  • February 15, 2021
There is a time returned in the data which looks like a UNIX timestamp, you should be able to convert this to a datetime by dividing by 1000 and then using a DateTimeConverter with input %s
ronnie.utter
  • February 15, 2021
aa,, ok. I was wondering what kind of timeformat that was. Thanks. I will try that.
ronnie.utter
  • February 15, 2021
Thank you all. !!!
  • February 15, 2021
Thank you all. !!!
Capture
ronnie.utter
  • February 15, 2021
Capture
Thanks,
Ive learned something new today.
It works.
