Single quote (apostrophe) in published parameter when submitting a job through FME REST
  • Oct 7, 2022 8:43 AM UTC
  • 196 views
nielsgerrits
Forum|alt.badge.img+67
We have a workspace on FME server (2021.2.6) with a published parameter ProjectName.
We're submitting jobs through the REST enpoint, using json for the parameters.
Now we have a project name with an single quote (apostrophe), like:
A'dam
This results in a code 400 - bad request.
So, what is the correct way to send this string in the json? What we have tried:
A%27dam
This works, but then we need to decode the string in workbench.
A\'dam
This works, but server interprets this as as a double quote.
A"dam
We also tried to replicate this in submitting a job from the fme server interface but then the parameters are sent as form data, not as json...
merlinegeorge
Hello @nielsgerrits​ ,
Could you please test if this works- To use an apostrophe or a single quotation mark (') in a value, add another single quotation mark after the first one.
For example - the value O'Hara can be submitted as  "O''HARA".
nielsgerrits
Hej @Merline George​ , thanks for looking into this. I tried replacing a single quote with 2 single quotes:
"TMDirectives": {
"ttl": 60,
"description": "",
"priority": 100,
"tag": "Normal"
"publishedParameters": [
"name": "ProjectNaam",
"value": "A''dam"
"subsection": "REST_SERVICE"
But I still get
The remote server returned an error: (400) Bad Request.
when submitting the job. We initiate the job using /fmerest/v3/transformations/submit/.
