Shapefile generated in FME doesn't work in lastools
  • Jan 10, 2023 12:13 AM UTC
  • 6 replies
  • 87 views
james_c_452
Forum|alt.badge.img+10
Does anyone know why a shapefile generated in FME would not work in lastools? I am using lastools to clip a point cloud using a buffer from FME but it can't read the shapefile. I don't know why it is invalid, only that my command line has the following errorimageAny help would be appreciated
Thanks
f.kemminje
Forum|alt.badge.img+11
  • Jan 10, 2023 4:24 AM UTC
try ...give the specific files name. no wildcard *.shp.
Maybe it works.
james_c_452
  • Jan 10, 2023 4:31 AM UTC
Maybe it works.
Thanks for the reply f.kemminje. I did try that before I asked. There's probably some random little thing that lastools doesn't like. Just not sure what
Forum|alt.badge.img+63
Have you tried opening the shapefile in another application? Any chance you can share it here?
DanAtSafe
Forum|alt.badge.img+23
  • Jan 10, 2023 5:05 PM UTC
Can the shapefile be read by ArcGIS? If so then lastools requires a non-standard shapefile. There are some exceptions - see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/shapefile/troubleshooting.htm
james_c_452
  • Jan 13, 2023 4:19 AM UTC
Update, I can get it to work if I use a geometry validator before I write it. Use all settings (but remove the two OCG checks), turn on checking for self intersecting, and I also remove vertexes closer than 0.1m (but I don't think you need this last step). I also dissolved before the validator in one case
james_c_452
  • Mar 31, 2023 4:10 AM UTC
Second update, I had this problem again for a different reason. This time it was fixed by having the Geometry in the shapefile write set to the appropriate type. Shape_polyline for my new case but probably shape_polygon for the case of this question
