Set ArcGIS Server Feature Service via FeatureReader with Spatial Filter via attribute
  • Jul 13, 2022 8:02 AM UTC
  • 86 views
caracadrian
Forum|alt.badge.img+23
I created a Custom transformer that contains a FeatureReader set as Esri ArcGIS Server Feature Service.
I want to set Spatial Filter via an attribute. For this I created a conditional attribute (DE-9IM) with values TT*TT**** for Intersects and ********* for <No Spatial Filter>. If the case is that there is no filter, a conditional WHERE CLAUSE activates.
The problem is if the case is that there is no spatial filter the FeatureReader returns no data.
What is the corect DE-9IM value for <No Spatial Filter>?
hkingsbury
Forum|alt.badge.img+73
  • Jul 13, 2022 8:46 PM UTC
This may be over thinking it, but if there is no option for <No Spatial Filter> you could make a HTTP call to the service to extract its bounds, then use that geom as the spatial filter
caracadrian
  • Jul 14, 2022 5:09 AM UTC
That would be overthinking it 😀
FeatureReader actually has a Conditional Value option for Spatial Filter, but I want to set it up via attribute:
Spatial Filter conditional valueAnd it doesn't display correctly...
After fiddling around with this for an entire day I just want to find the DE-9IM solution.
