resolve attribute references in comments in XMLTemplater
  • Dec 15, 2022 7:30 PM UTC
  • 81 views
jdh
Forum|alt.badge.img+41
I'm trying to create an xml document where part of the information in the comment is coming from an attribute. However in the XMLTemplater everything within a comment is output untouched, including {fme:get-attribute("_comment")}.
Thoughts on how to work around this?
Attached is a sample workspace demonstrating the issue.
Build 2022.0
If I create an attribute in advance: <!-- comment should resolve attribute @Value(_creation_instance)--> and use {fme:get-attribute("_comment")},
then the braces are replaced with &ly; and &gt;.
If I use {fme:get-xml-attribute("_comment")},
there are some xml parsing warnings:
XMLTemplater (XMLTemplaterFactory): The following error occurred near line 1, column 51 of the query:
XMLTemplater (XMLTemplaterFactory): invalid content passed to fn:parse-xml(): loader parsing error: Extra content at the end of the document
and the resultant xml does not contain the comment at all.
thijsknapen
Forum|alt.badge.img+12
  • Dec 15, 2022 9:06 PM UTC
Hi @jdh,
Isn't this what you are looking for: xquery - Write expression inside xml comment - Stack Overflow?
In your case, try to replace the following:
<!-- comment should resolve attribute {fme:get-attribute("_comment")}-->
with:
{comment {concat('comment should resolve attribute ',fme:get-attribute("_comment")) }}
jdh
  • Dec 15, 2022 9:13 PM UTC
Hi @jdh,
with:
That does seem to do the trick, though I will probably build the full comment outside and just use {comment {fme:get-attribute("_comment")}}
thijsknapen
  • Dec 15, 2022 9:14 PM UTC
sure, that's up to you :)
