replace raster cell negative values with abs(value) is it possible?
  • Aug 18, 2020 2:35 PM UTC
  • 111 views
oliver.morris
Forum|alt.badge.img+14
I would like to replace any negative raster cell values with their positive equivalent either using abs(value) or another other means. Is this possible with a transformer, can I obtain the cell value and use rastercellvaluereplacer?
Thank you for your help
Best answer by ebygomm
Have you looked at the RasterExpressionEvaluator?
Forum|alt.badge.img+54
  • Aug 18, 2020 3:00 PM UTC
oliver.morris
  • Aug 18, 2020 3:43 PM UTC
Thanks that worked perfectly.
oliver.morris
  • Aug 18, 2020 3:44 PM UTC
Capture
