Reges expression problem
  • Jan 13, 2023 3:58 PM UTC
  • 98 views
spiderman
Forum|alt.badge.img+7
Hello ,
I am not sure how to use Regex expression
First example :
street name 34 (56)
street name 56 ( 44 )
street name 55(70) or street name 55( 70 )
I would like to extract the number between parentheses and add - before the number
so it should be street name 34 - 56
second example :
street name 56 (text)
street name 40 ( text )
street name 10(text)
street name 40( text )
i would like to extract the text between parentheses and create it in new column
third example :
street name 20 ( GdR 20 )
street name 22 (23-50)
I would like to extract it and add - before the value in parentheses
So it should be street name 20 - GdR 20
thanks in advance
FME 2021
Best answer by danilo_fme
Thanks .ur idea is simple and really good .
but I have at the same attribute ,
as example street name 12 (gfsjj dhl) or
street name (fhjk)
I would like to keep the values before parentheses
and remove parentheses and the rest .
so Output will be street name 12 instead of street name 12 (gfsjj dhl)
How could I achieve it ?
Hi @spiderman​
If you want to delete word with parentheses, you can use this Workspace attached.
Workspace_1
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Jan 13, 2023 9:11 PM UTC
Hi @spiderman​
I created a Workspace that replacer the ( ):
Attribute_
Please, see the Workspace attached.
Thanks in Advance,
Danilo
spiderman
  • Jan 14, 2023 6:16 AM UTC
Hi @spiderman​
Attribute_
Thanks in Advance,
Danilo
street name (fhjk)
danilo_fme
  • Jan 15, 2023 10:42 AM UTC
street name (fhjk)
Hi @spiderman​
Workspace_1
Thanks in Advance,
Danilo
