Real Surface Calculation from DEM
  • July 28, 2021
  • 108 views
jugoslaviaa
Is there any tool to calculate real surface from DEM which similar to this tool from SAGA http://www.saga-gis.org/saga_tool_doc/2.1.3/ta_morphometry_6.html? It mainly takes into account the slope while calculating the surface area!
Thanks in advance
Best answer by caracadrian
Use AreaCalculator with Type set to Slope Area.
If needed send the DEM to the Points/Lines port of a SurfaceModeller and calculate the area of the features outputed from the TINSurface (or Triangles) port.
caracadrian
Forum|alt.badge.img+23
  • July 28, 2021
